SECURIFI ALMOND 2015 LONG RANGE TOUCHSCREEN WIRELESS N300 ROUTER - RANGE EXTENDER PLUS HOME AUTOMATION HUB - 3 MINUTE SETUP
Securifi Almond 2015 Long Range Touchscreen Wireless N300 Router / Range Extender + Home Automation Hub (3 Minute Setup) Wireless Data Rates: Up to 300Mbps Frequency Band: 2.4 GHz WAN Ports: 1 x 10/100M Security: TCP / IP, UDP, ICMP, PPPoE, PPTP, NAT/PAT, DHCP WPA/WPA2: WEP, WPA, WPA2 LAN Ports: 4 x 10/100M Modulation: DSSS, OFDM, MIMO Antenna: Internal Antenna
Price: 79.99
